It is currently Mon Sep 15, 2025 5:08 am
Post new topic Reply to topic  [ 1839 posts ]  Go to page Previous  1 ... 56, 57, 58, 59, 60, 61, 62 ... 74  Next
PostPosted: Sun May 05, 2024 9:37 pm
First name: Brad
Last Name: Combs
Coming soon… :)
Brad
These users thanked the author bcombs510 for the post (total 2): Kbore (Mon May 20, 2024 11:56 am) • Hesh (Mon May 06, 2024 4:23 am)
PostPosted: Mon May 06, 2024 2:01 am
Optimist Primed…Image
These users thanked the author meddlingfool for the post (total 5): Kbore (Mon May 13, 2024 8:56 pm) • Durero (Wed May 08, 2024 12:50 am) • SteveSmith (Mon May 06, 2024 6:12 am) • Hesh (Mon May 06, 2024 4:24 am) • bcombs510 (Mon May 06, 2024 4:09 am)
PostPosted: Mon May 13, 2024 9:16 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Hesh wrote:
For an OLF tub of lard who wants to be the first one to correctly guess why we nip with the nippers horizontal and not vertical?
** Offer null and void for people who took our classes, only one entry per participant, offer not valid in states where it's prohibited. ;)
I don't know why to use them horizontal and not vertical.
I split the difference and do mine at a 45, with the bottom of the diagonal cut (closest to the bench and furthest away from FB) pointing toward the tail block. I reason that it will direct any torque on the fret wire from the file teeth, down, toward the fingerboard slot, and not up and away from the fingerboard slot. I may be incorrect but at least it is purposeful.
I'm all ears! The construct of that sentence is kinda funny. It could imply that I am an OLF tub of lard..... except that I didn't guess correctly...:lol:
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: Hesh (Tue May 14, 2024 5:46 am)
PostPosted: Tue May 14, 2024 5:50 am
OK you use the nippers horizontally where possible, it's not possible on the fret board extension on an acoustic so that as the jaws squeeze the fret before the metal fractures and cuts "fangs" do not form on the fret end. Fangs are like the name implies two fang like points pointing downward that look like crap, will go proud of the neck and even cut hands if a neck is severely dried out and they require us to remove them with files concentrating on the fangs.
With the nippers horizontal the fangs do not form or happen solving the problem before it occurs and eliminating the unnecessary step of filing the fangs away.
These users thanked the author Hesh for the post: Kbore (Tue May 14, 2024 10:13 am)
PostPosted: Tue May 14, 2024 5:59 am
rbuddy wrote:
Great video Brad, but I couldn't figure out what was happening at 7-10 seconds. Is that a fret doctor to file back barbs on the tang? If so, what is your theory there.
Hesh, I'll bite -- cause that's the way the Summit nippers work those are the nippers I use too. I always bind fingerboards so the tangs are nipped off at the ends ahead of fretting. As such, I always nipped with the old style nipper with the cutting edge perpendicular to the FB. Reasoning has been it is less likely to send a shock wave up the fret possibly unseating it IMO. Change my mind.
Thanks guys!
Yeah it doesn't matter if there is tang or not we cut with the jaws of any nippers horizontally to prevent the formation of "fangs" which result from cutting the the nippers vertically as the jaws distort and bend the fret wire prior to fracturing it. The fangs are an added step to get rid of that can be completely avoided with the jaws horizontal where possible.
I don't have a pic of fangs but they look like two little fangs sticking down as a remnant from fret wire distortion prior to fracturing. They can be felt, they look like **** and when the neck dries out they go proud and can even be sharp enough to cut hands.
These users thanked the author Hesh for the post (total 3): rbuddy (Tue May 14, 2024 10:27 am) • Kbore (Tue May 14, 2024 10:15 am) • bcombs510 (Tue May 14, 2024 9:00 am)
PostPosted: Tue May 14, 2024 9:05 am
First name: Brad
Last Name: Combs
Brian, you're right that I am using the Jescar nippers in the video which require the horizontal cutting. I love these nippers but they do have a learning curve. You can see that I tape the edge of the fretboard to (hopefully) prevent any dings.
Like Hesh said, we were taught to cut them horizontally in the class an AAG and that is the way I always did it, even with the SM cutters. Hold them horizontal, slide the jaws up until the bottom jaw touches the fretboard, rock them left and right to create just a bit of space, and snip. It works really well.
These users thanked the author bcombs510 for the post (total 3): Hesh (Tue May 14, 2024 11:34 am) • rbuddy (Tue May 14, 2024 10:27 am) • Kbore (Tue May 14, 2024 10:16 am)
PostPosted: Tue May 14, 2024 10:11 am
City: U.P.
Thanks for the explanation guys!
I guess I switched to the Summit nippers about the same time I switched to stainless fret wire almost exclusively. Love those Summit nippers, almost cut flush with the fingerboard and even almost cut an appropriate angle on the fret end, great tool!
With nickel wire the little extra fang was not much of an issue.
I also grind my old modified nippers to a pretty sharp angle which didn't leave much fang. It did reduce lifespan of the nippers but left a pretty flat fret end.
My thought was, a $20 pair of Channel Lock end nippers may only last 3-4 fret jobs but $5 per neck wasn't a deal breaker for me.
I wanted to make sure I wasn't missing something.
Thanks, Brian
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 2): Hesh (Tue May 14, 2024 11:35 am) • bcombs510 (Tue May 14, 2024 10:16 am)
PostPosted: Tue May 14, 2024 11:45 am
I always try to avoid cutting flush and will rock the nippers as I hold them horizontally to make sure I'm not going to contact the neck and finish when they start to slice through the fret. So then I rely on my files that we make for taking the fret ends down flush while not damaging the finish.
There have been several iterations over the years of StewMac nippers based on the Channel Lock tool. Dave's from 20+ years ago have cut stainless for maybe a couple hundred fret jobs and are still sharp. Mine from 18 years ago also cut stainless and although not as much use as Dave's mine are still sharp but have other differences from Dave's.
His have a greater bevel angle which was originally intended to get under a fret and "lift" it out of the slot with the wedge of the bevel and flat face in contact with the board. Never "pull" a fret upward as that damages the fret slot and takes wood with it. Mine have less of a bevel and don't "lift" a fret as well.
So originally if you talk with some of the career folks you will learn that the tool had two purposes one to cut fret ends and the other to "lift" frets out of the slot when we refret while holding the flats of the face firmly against the board preventing chipping. Close the jaws under a seated fret and the bevel gently lifts the fret as the flat face of the tool presses against the board preventing chipping.
Over time this second function has been lost to time and the current unavailability of nippers with a proper lifting bevel and flat face.
We should get Dave some of the Summit nippers they look great to me but if I advocate for them he won't like them... ;)
These users thanked the author Hesh for the post: Kbore (Wed May 15, 2024 8:25 pm)
PostPosted: Tue May 14, 2024 1:22 pm
City: U.P.
I had one shot of a freshly nipped stainless fret, cut with the Summit/Jescar nipper. Just in a block of maple flooring I had handy while testing the nipper.
Straight from the nipper, no filing.
Hopefully you can see why I like them.
N8ZED
These users thanked the author rbuddy for the post (total 2): Kbore (Wed May 15, 2024 8:25 pm) • Hesh (Tue May 14, 2024 6:12 pm)
PostPosted: Tue May 14, 2024 2:03 pm
First name: Brad
Last Name: Combs
Yes! I had a repair person from North Carolina reach out to me after I posted the video to instagram asking for a close up. Here is what I sent him….
That’s just the nipper!
Brad
These users thanked the author bcombs510 for the post (total 2): Kbore (Wed May 15, 2024 8:26 pm) • Hesh (Tue May 14, 2024 6:13 pm)
PostPosted: Tue May 14, 2024 6:24 pm
I was trying to see if I could search the OLF rooms for a picture of fangs since I don't and won't own a single guitar with them and I did not find a pic. But I did find one of the first times we discussed fangs and how Dave Collins uses the nippers horizontally to avoid pinching the fret sides and creating fangs in the first place. The entire thread is a good read if you are interested in the details.
What I did not mention this time when discussing fangs Dave brings up that the pinch also pushes the fangs into the wood of the side and top of the fretboard creating a visible defect/dent forever more.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=44767&p=591819&hilit=fangs#p591819
These users thanked the author Hesh for the post (total 2): Kbore (Wed May 15, 2024 8:26 pm) • bcombs510 (Tue May 14, 2024 6:30 pm)
PostPosted: Fri May 17, 2024 10:34 am
First name: Zac
Last Name: Stout
City: Floyd
State: VA
Zip/Postal Code: 24091
Fretboards, headplates and bridges for the batch of four I’ve been working on. The unfretted board is waiting on me to decide whether or not I’m going to do the inlay I posted about last month…I’ve been playing around with a couple different ideas but haven’t quite hit the mark yet.
Glued the first of the fretboards to a neck yesterday…excited to be nearing the finish line on these guitars and finally getting to hear them!
These users thanked the author Zac Stout for the post (total 5): Kbore (Mon May 20, 2024 12:00 pm) • Robbie_McD (Sun May 19, 2024 8:18 pm) • Hesh (Fri May 17, 2024 11:47 am) • doncaparker (Fri May 17, 2024 10:58 am) • bcombs510 (Fri May 17, 2024 10:47 am)
PostPosted: Fri May 17, 2024 11:34 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Assembling my new buffer. I made the base this morning from scrap. I spent a ridiculous amount of time removing the old motor from the sander. Ended up breaking out the angle grinder to remove the last rusted screw. Now I'm exhausted and will get back to it tomorrow.
Hutch
These users thanked the author banjopicks for the post (total 4): Kbore (Mon May 20, 2024 12:01 pm) • SteveSmith (Fri May 17, 2024 2:45 pm) • bcombs510 (Fri May 17, 2024 12:04 pm) • Hesh (Fri May 17, 2024 11:47 am)
PostPosted: Sun May 19, 2024 12:17 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Finished up this Madagascan rosewood and Italian spruce short scale guitar and boxed it up only to realize I forgot to make and install an armrest while driving to UPS store. She's off to her new home now
These users thanked the author oval soundhole for the post (total 6): Pat Foster (Mon May 20, 2024 10:24 pm) • Kbore (Mon May 20, 2024 12:01 pm) • Robbie_McD (Sun May 19, 2024 8:20 pm) • Durero (Sun May 19, 2024 5:07 pm) • bcombs510 (Sun May 19, 2024 1:02 pm) • Hesh (Sun May 19, 2024 12:19 pm)
PostPosted: Tue May 21, 2024 8:53 am
City: U.P.
Another beauty Brian. How are you attaching the arm rest? Is it removable?
N8ZED
PostPosted: Tue May 21, 2024 3:29 pm
Got a couple of OMs back from finish. Getting the bridges on etc.
Have a couple of tire kickers interested but most likely they’ll go on the wall at the store where I sell.
ImageIMG_9290 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 4): Kbore (Wed May 22, 2024 2:53 pm) • rbuddy (Tue May 21, 2024 5:25 pm) • Chris Pile (Tue May 21, 2024 4:26 pm) • bcombs510 (Tue May 21, 2024 3:51 pm)
PostPosted: Wed May 22, 2024 5:43 am
Nice! Who does the finish work?
PostPosted: Wed May 22, 2024 6:46 am
First name: Richard
City: Warwick
State: RI
Buffed out the finish on #1. I could get it better but this has too many problems to be worried about looks. Mainly because of this.
It's going to be a player in spite of the build faults.
Hutch
These users thanked the author banjopicks for the post: Kbore (Wed May 22, 2024 2:52 pm)
PostPosted: Wed May 22, 2024 7:02 am
First name: Brad
Last Name: Combs
Hey, looking nice, Hutch!
Tony Ferguson
PostPosted: Wed May 22, 2024 7:33 am
First name: Richard
City: Warwick
State: RI
I forgot to mention, the finish is SM acrylic. This is my first time having any success with it and after seeing this. I'm going to try to do a better job on #2. I love being able to spray in my basement. Just open a window and put any kind of fan in it. Nice!
Hutch
PostPosted: Wed May 22, 2024 3:30 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I started gluing together the little baroque guitar/8 string uke. It has a concave belly. I carved a dish into a board, and made a plaster form to get the dome. The bridge goes on first so you need to have a cutout for it. I flung quite a few of those sticks!
I have been doing the viola ribcage. Katalox "binding" on the edge. I have the c bouts done, and the rest of the ribs and linings glued on. I never spent so much time on ribs in my life. It should look very cool. Photos when done.
Why be normal?
These users thanked the author Ken Nagy for the post (total 3): Kbore (Wed May 22, 2024 4:53 pm) • Chris Pile (Wed May 22, 2024 4:29 pm) • bcombs510 (Wed May 22, 2024 3:36 pm)
PostPosted: Wed May 22, 2024 5:05 pm
First name: Karl
Last Name: Borum
Number 3 finally finished and I’m really glad to have this one behind me. [uncle] It fell 3 feet to the concrete floor last June during final wet sanding, cracked the top and shattered the lacquer at the impact point. It’s basically a rescue now, but it’s finished. Torrified Sitka top and braces and East Indian rosewood back sides, FB and bridge. Bone saddle, nut and pins.
Posting the pic, I see I need to make a pick guard. Maybe I go with clear in lieu of the tortoise I normally use?
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 2): rbuddy (Thu May 23, 2024 10:55 am) • bcombs510 (Wed May 22, 2024 6:10 pm)
PostPosted: Wed May 22, 2024 6:11 pm
First name: Brad
Last Name: Combs
Looks great and congrats!!
How’s it sound? I bet it’s a cannon with the torrified top?
These users thanked the author bcombs510 for the post: Kbore (Thu May 23, 2024 11:01 am)
PostPosted: Wed May 22, 2024 6:58 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I've made 5 but one kept losing the bridge (this barogue one has "bridge keeper" braces, original in 1700 or so. One was a little too light, and I haven't got the neck right yet. So making the save is a good thing.
Why be normal?
These users thanked the author Ken Nagy for the post: Kbore (Thu May 23, 2024 11:02 am)
Users browsing this forum: No registered users and 45 guests
